SnakePlissken81
Message 1 of 12
Fan noise!
Disappointed with my new v6 box which arrived 4 days ago.  The constant fan noise (it sounds like a fan not an HD) is driving me nuts.  My old Tivo was pretty much silent.  The box makes this noise even on standby.  It has also rebooted twice during recordings (recording 1 channel not several) and has frozen on playback twice necessitating a power off and on.  I think I may have to cancel and go back to the tivo even though i like the speed of the new box when it works.  If all of these boxes have this fan noise then I would rather not have the thing in the house!  Does anyone have a quiet one of these things?
  • 8.89K
  • 612
  • 1.76K
Message 2 of 12
Re: Fan noise!
mine's totally silent
  • 45
  • 6
  • 10
Marni1971
Dialled in
Message 3 of 12
Re: Fan noise!
Mines silent too. The HDD click is more noticeable - and for that the rest of the room has to be silent. Even then it's barely noticeable.
Ring 150 and see about a swap.
  • 11.71K
  • 1.11K
  • 2.42K
Message 4 of 12
Re: Fan noise!
You can hear the fan if you put your ear right next to the box while in standby. In normal circumstances, it's not noticeable.
SnakePlissken81
Message 5 of 12
Re: Fan noise!
Thanks for the replies.  Have phoned for an engineer.  Worry they won't hear the noise!
  • 8.94K
  • 386
  • 629
Message 6 of 12
Re: Fan noise!
Hi SnakePlissken81,
Welcome to the Community!
Sorry to hear you've had trouble with a noisy V6.
I've located your account and I can see the technician has been out to fix this for you. How's it been since?
Speak soon Smiley Very Happy
Josh
SnakePlissken81
Message 7 of 12
Re: Fan noise!
Josh,
The engineer replaced the box but he also worked there was a problem with the signal which he fixed.  The new box is actually not much quieter than the last but I'm starting not to notice it so all is good.
  • 7
mrtuk83
Message 8 of 12
Re: Fan noise!
My box is also very noisy! I can hear 2 things in my room the clock ticking and the v6 box humming away urghh sounds like a laptop fan humming away.
  • 4.04K
  • 202
  • 903
cybmole
Community elder
Message 9 of 12
Re: Fan noise!
this is not the best week for forming an opinion on normal fan noise.
your room is probably 10 degrees hotter than usual
  • 11.71K
  • 1.11K
  • 2.42K
Message 10 of 12
Re: Fan noise!
You likely have hyperacusis (like me) - a condition where quiet, repetitive sounds can be very irritating.
