  • 112
JohnWB
Does the IR remote input still work when the wireless remote is paired
I am getting a V6 installed tomorrow and, as i use an IR Harmony remote, i was wondering, does the IR remote input still work when the wireless remote is paired with the V6 box.
Helpful Answers
  • 10.31K
  • 918
  • 2.1K
Re: Does the IR remote input still work when the wireless remote is paired
Yes, V6 still responds to an old TiVo remote at the same time as a paired V6 remote.
This means that Harmony products will continue to function a la TiVo previously.
All Replies
  • 10.31K
  • 918
  • 2.1K
  • 112
JohnWB
Great, thanks for that
