BristolKeithUK
Difficulty getting picture and sound when switching TV on with V6 box
Got a Samsung smart TV connected to a V6 box.
not getting picture or sound when turning on TV and have to turn off TV three or four times to get anything, the picture when appears flickers once or twice then either stays or disappears, it's almost that the signal from the V6 box doesn't stay on long enough for the TV to recognise.
have reset the V6 box many times, have reset TV back to factory settings, tried different HDMI cables including fast ones, now using cable that came with the box, no good contacting support as all they say is "turn everything off then back on"
Helpful Answers
  • 580
  • 50
  • 135
Corinneangela
Rising star
Re: Difficulty getting picture and sound when switching TV on with V6 box
Try the fix in the opening post of this thread http://community.virginmedia.com/t5/Virgin-TV-V6/Samsung-KS8000-9000-V6-black-screen-solved/m-p/3336... looks like it might be your issue.
All Replies
  • 580
  • 50
  • 135
Corinneangela
Rising star
BristolKeithUK
No didn't work, although picture flashed up once then went off
BristolKeithUK
Thanks very much, problem solved this morning after switching tv on by button on back, think it needed that to set TV's to change
