Mcleary1
Connecting V6 to a Bose 321 system
Hi all,  I have just switched to Virgin from Sky and I cannot get the new V6 box to split the sound from the audio.  I have connected with an HDMI cable from TiVo to Tvr and a digital audio cable from TiVo to Bose system.  No sound from the home cinema.  Does anyone know how to connect these?
  • 925
  • 90
  • 171
LittleMick73
Well-informed
Re: Connecting V6 to a Bose 321 system
If your TV has an optical port try connecting direct from bose to TV, as you are connected via HDMI the sound just takes a different route, I have my 5.1 system connected that way it works perfectly.Regards Micky
Mcleary1
Thanks very much. That and a setting change in the Bose settings to tell it where the sound was coming from worked.
