on 29-07-2016 20:27
To solve these problems with your Virgin Media home phone, check your equipment:
There’s no dial tone, or there’s a crackling on the line
Your phone doesn’t ring or receive incoming calls
Run through these checks:
You receive incoming calls, but can’t call out
Check that your phone isn’t faulty as above. Also, check that you haven’t activated outgoing Call Barring. If payments are overdue on your account we may have put a temporary restriction on the outgoing calls you can make. If this happens you can of course still call emergency numbers.
Read on if you’re experiencing these problems:
Free Voicemail isn’t working
Have you contacted us to add this service to your account? You don’t get this service automatically, so make sure you tell us to set it up for you.
Check that you have activated the Voicemail service from your home phone by dialling 1571 and following the instructions.
The phone rings three times only before going to Voicemail
If you have a digital cordless phone you might notice that it sometimes rings just three times before going to voicemail, and there may be a delay in the caller display. This happens because you don’t get to hear the first two rings: the phone is busy with the information it needs to identify the caller. This is also the reason for a delay in the caller display appearing.
So, how can you fix this? If you want more time to get to the phone, just call us to set it up. The default is usually five rings but this can be extended to up to ten rings. Call 150 from your Virgin Media phone or mobile, or 0345 454 1111* from any other phone.
You can’t access voicemail messages
Your phone might not be set up correctly, or not switched to a tone setting. The switch is usually at the side or underneath the phone.
You forgot your Call Barring PIN number
Just give us a call and we’ll reset it for you. Call 150 from your Virgin Media phone or mobile, or 0345 454 1111* from any other phone
What is this Recall (R) button for?
Don’t confuse Recall (R) with Redial – they’re completely different things! The Recall (R) button needs to be pressed to use some features such as three-way calling. Press R and you’ll hear a different dial tone. If this doesn’t work, make sure the Selector switch is set to Timed, Timed Break Recall or T. The other setting is generally used for switchboards and doesn’t work on residential lines.
How else can I help myself?
Check out our Service Status area where you can see known outages on the telephone network. You’ll also find straightforward tests that’ll check for faults on your own phone line. If there are you can book an engineer online too.
Alternatively, you can test your home phone services by calling our automated phone service on 150 from your Virgin Media phone or mobile, or 0345 454 1111* from any other phone
Or why not pop over to virginmedia.com/community, select 'Help forum' and join in the conversation on the Virgin Phone board. There are many clever members and someone usually knows the answer!
* For details about how much it costs to call our team from a Virgin Media home phone, visit www.virginmedia.com/callcosts. Call costs from other networks and mobiles vary.
