Ojam
Phone not working no dial tone incoming or out coming
Phone is dead no dial tone and when phoned from mobile doesn't ring but mobile rings as if it is. Changed phone points and still doesn't work. So no incoming calls or out going call any ideas what to do
  • 7.14K
  • 231
  • 523
Re: Phone not working no dial tone incoming or out coming
Hi Ojam,
Welcome to the Community and thanks for posting on the Forum. I'm sorry that you have no dial tone on your landline.
I have been able to access your account via your Forum details and run testing on your line. I can see that there are no outages reported for your area and the test results aren't indicating what is causing this issue, so we will need for you to check your equipment.
If the below checks have already been done, I can schedule an engineer to call out to get this fixed for you.
Please verify the following checks have been done:
  • Check the phone – Please try another phone to check if the line is the issue (required on no dial tone faults). Is the phone turned on and if it is, are the batteries correctly inserted & charged? **If you don't have an alternative phone handset to try, please try your phone on a different landline (friend/relative/neighbour's landline) and see if it works**
  • Check the socket – Check the phone is plugged into the right socket; you’d be surprised how often it’s not. Ensure it is plugged into the Virgin Media socket with the logo or if no logo exists, the correct phone socket.
  • Check the extension – Is it connected properly? Does the problem persist if the phone is plugged directly into the Virgin Media socket with the logo or if no logo exists, the correct phone socket?
I'll send you a private message requesting further details so that I can arrange an appointment for you if you are still having the fault on the line after doing the above checks. Just click the purple envelope at the top right of this page.
Kind regards,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
