  • 9
Sally480
Phone not ringing with incoming calls
Hi all,
My phoneline doesn't seem to be working with incoming calls, sometimes it rings once or twice and then cuts off. Outgoing is absolutely fine. I'm not really sure what the problem is, I have bought a new phone and tried that however have found the exact same problem.
I had wondered why I hadn't received calls to my phoneline for a while and I believe this has been affecting me for a while.
Thanks for your help.
  • 6.6K
  • 254
  • 379
Re: Phone not ringing with incoming calls
Hello Sally480,
Welcome to the community.
Since you have changed the equipment already what I would like to do next is to arrange for a technician to visit your property so I'm just going to send you a private message with appointment times which you will find if you click on the purple envelope at the top right of the screen.
Speak to you soon
Rose
