Roundthetwist
Nokia 630 phone . Charged phone reverts to battery saver mode
Following full charging and removal from charger, the phone reverts to battery saver mode with limited life for calls etc. I have installed new battery but problem persists. I don't use the phone very much so it is not excessive usage
  • 8.67K
  • 590
  • 1.72K
Re: Nokia 630 phone . Charged phone reverts to battery saver mode
according to nokia that's a battery saver option
The battery saver mode allows you to significantly extend the battery life of your device. Once this mode is enable all unnecessary services will be disable ( GPS, background services, auto-update...etc).
To enable the Battery Saver Mode of your Nokia Lumia smartphone:
  • Tap on the Start key > Settings > Battery Saver
  • Select between:
    • "Always turn on Battery Saver mode when battery is low" - To automatically switch to battery saver mode once the phone's battery has gone down to a certain level.
    • "Turn on Battery Saver mode now, until next charge" - Switch immediately to Battery saver mode.
