mikerawse
No dial tone; same for 3 neighbours. How to convince VM it's a system fault.
Called In fault, also two other neighbours did same, all offered engineer call well into new year. Come on this is so obviously a common fault somewhere! Co-ordinate your fault calls!
  • 7.35K
  • 304
  • 650
Moderator
Moderator
Re: No dial tone; same for 3 neighbours. How to convince VM it's a system fault.
Hi there mikerawse,
Firstly I'd like to welcome you to the forums and say that I'm really sorry to hear that you've had some issues with your phone line.
With our phone service we do need a number of customers to call reporting a fault in order to detect a fault. I can see that shortly after you made this post we did indeed get enough reports from the same part of the network to instigate a network outage.
The fault was cleared yesterday afternoon, so hopefully your phone, and your neighbours' lines are all now working. Should you still be experiencing an issue please let me know so I can investigate further for you.
Many thanks and apologies again.
Huw
