debbiemccart
Help - landline not working!
Our land line has not been working for days
No incoming calls and we can't dial out
message on handset screen: 'line cord error please check'   - check what?
How do I report this to get it fixed?
  • 6.61K
  • 255
  • 379
Re: Help - landline not working!
Hello debbiemccart,
I have tested your line and I'm not finding any faults at the moment so before I'm able to arrange for a technician I would just like to confirm whether you have tried another handset in the Virgin Media socket just to eliminate any equipment fault?
Looking forward to hearing from you.
Rose
debbiemccart
Hi Rose
Thanks for your speedy reply
We have just tried a different hand set on the same base unit with the same result and same message
Please advise
Debbie
  • 6.61K
  • 255
  • 379
Thanks for getting back to me Debbie,
What I would like to do next is to arrange for a technician to visit your property so I'm just going to send you a private message with appointment times which you will find if you click on the purple envelope at the top right of the screen.
Speak to you soon.
Rose
