leannejaay
First time using home phone line won't ring out or receive incoming
Hi I have a technical query,
with my home phone are you able to help?
Not sure I chose the right option? I have been with yourself a for a while now (broadband, TV and home) and I get a home line with my package, the mast is down in my area and the EE network isn't working so I've decided to plug my home phone in, so I can make calls(something I should have done a long time ago as I have free calls!). Any how I've plugged it into the right bit etc, made sure all of that, it's dialling then does that weird tone when I type the number I want to call; like it won't connect ? It does that 3 pitched tone noise do you know what I mean? Tried 150 also nothing. Not sure if it needs to be activated first or what?! But won't ring out or incoming either?
  • 7.79K
  • 337
  • 547
Re: First time using home phone line won't ring out or receive incoming
Hi leannejaay,
Welcome to the Community!
Really sorry to hear you're having trouble with your landline.
I've run a diagnostic on the line and everything is showing clear at the moment. When you pick up the handset do you get a dialling tone? Do you have another handset you can test in the socket?
Speak soon Smiley Very Happy
Josh
leannejaay
Hiya! It dials yes then does that weird tone when I press call, it's the weird tone that's like 3 pitched noise if that makes sense, **bleep bleep bleep*** but with a higher pitch each bleep 3 times then nothing? U know what I mean? I'm so dopey when it comes to things like this! Lol and no I don't! It's a brand new home phone set I have I've followed all instructions to set it up which obviously I have correctly. I think an engineer might need to look at it:/
  • 7.79K
  • 337
  • 547
Hi leannejay,
No worries!
I've sent you a private message (purple envelope at the top right of your screen) so I can arrange for a technician to take a look.
Josh
