  • 22
Vortexmind
Connecting a phone to Hub 3.0
could someone help me around the set up of the Hub 3.0 ? I see that there are two sockets for the phone line, however when I connect my phone there it does not work.
Any ideas?
Helpful Answers
  • 8.29K
  • 516
  • 2.3K
Re: Connecting a phone to Hub 3.0
VOIP (connecting a phone to it) is a future possibility (likelihood more accurately) but the phone sockets do nothing at the minute.
If you have a VM phone line as part of your package there will be a separate wall mounted socket to plug your phone into....
All Replies
  • 8.29K
  • 516
  • 2.3K
