  • 15
Bezcom
Call Barring Help!
Ok, so after having the old BT scam, I decided to get call barring.... after following the instructions from the Tech Guy I have managed to bar all OUT GOING calls from my VM landline, need help to cancel it as I now can't dial out! Smiley Embarassed
PROBLEM SOLVED!!!
  • 13.7K
  • 561
  • 959
Re: Call Barring Help!
Hi Bezcom
Sorry to hear about the problems you're experiencing in trying to cancel call barring, when trying to cancel, press #34, then * and you will be asked to enter your 4 digit PIN. After that, press # once more and that should cancel it.
You can find instructions on how to do this by [clicking here]
I'd love to hear how it goes
Craig
  • 15
Bezcom
Hi Craig, I found the answer in a previous post. Have removed it from my package as it's no use to me. Thanks for the reply.
  • 13.7K
  • 561
  • 959
Hi Bezcom
Thanks for taking the time to let me know about this, I'm glad to hear you've sorted this.
Sorry again for the inconvenience caused
Craig
