lindam72
Message 1 of 5
voicemail pin number
I don;t know my pin number to pick up voicemail from my landline.
My mobile went on fire and has no charge so I can't do anything from the handset and i don't have an old handset to swap over.
Any ideas?
  • 1.58K
  • 101
  • 270
Message 2 of 5
Re: voicemail pin number
Try 1210, 0000 and 1234.
Assuming you haven't changed it from the default.
lindam72
Message 3 of 5
Thanks.
Tried all those.
Nothing!
  • 1.58K
  • 101
  • 270
Message 4 of 5
It's likely you've changed the PIN - as far as I'm aware, the only way to get your messages would be to put the SIM into another handset and listen to them there and/or change the PIN.
Don't get too upset if you end up having to jump through hoops to get Virgin to reset it for you. The phone hacking scandal is fresh in everyone's minds.
lindam72
Message 5 of 5
Thanks.
i thought so myself but just wanted to put it out there.
