gurjbhamra
voicemail issues
voicemail not working since changing to 4g sim. spoke to cs who said its been activated ring 222 and follow instructions. not worked anyone know what to do?
  • 7.9K
  • 246
  • 547
Re: voicemail issues
Hi gurjbhamra,
Thanks for your post on the Community Forum and welcome. I'm sorry that you're having a problem with your voicemail since upgrading to a 4G SIM. Is this working for you now?
If you are still having an issue with this, please send a private message to me with your name and mobile number, so that I can look into this further for you.
To PM me, simply:
  • Click on my forum name on the left of this post.
  • Go to my profile.
  • On the right had side, select the 'send me a message' option.
Kind regards,
Terri
Virgin Media Forum Team
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
  • 96
  • 8
  • 10
szaman81
Up to speed
I had a similar issue this is what i did to solve it
  • Logged into my online virgin account
  • Went to plan and devices tab
  • Scrolled down to the bottom
  • Went to manage my services
  • Scrolled down to voicemail
  • Turned voicemail off
  • Logged out.
  • After 30 minutes took the same steps but turn the voicemail on and logged out
  • After another 5 minutes from my mobile i dialed 222 and that setup my voicemail
This helped others on a different post
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
