gurjbhamra
voicemail issues
I have rung 789 to sort out voicemail they said vm is active on your phone just ring 222 and follow instructions. This has not worked help! Nobody can leave me a voicemail.
  • 96
  • 8
  • 10
szaman81
Up to speed
Re: voicemail issues
I had a similar issue this is what i did to solve it
  • Logged into my online virgin account
  • Went to plan and devices tab
  • Scrolled down to the bottom
  • Went to manage my services
  • Scrolled down to voicemail
  • Turned voicemail off
  • Logged out.
  • After 30 minutes took the same steps but turn the voicemail on and logged out
  • After another 5 minutes from my mobile i dialed 222 and that setup my voicemail
This helped others on a different post
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
