missgg
voicemail help !!!!
Forgot password i dont know how but did is there anything i can do..,
  • 1.58K
  • 101
  • 270
Re: voicemail help !!!!
Have you tried ringing the voicemail number from your handset and changing it there? Option 2 then option 1. You only ever need the PIN if you access your voicemail from a different number, not your Virgin Mobile number.
