  • 13
havince
smartcall help
so i understand that if my landline is for free calls at weekends you can only do a smartcall using your mobile using those mins for landline at weekend to avoid adding charges
but, can you use smartcall on your mobile using the wifi signal using NORMAL mobile mins at anytime? thus helping with indoor signal issues
Helpful Answers
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Re: smartcall help
Hi havince
It's a little quick answer - NO -
Edit: thought I'll add a bit more info, if the call is not a Smartcall, the call would be made as normal call from your mobile using the normal mobile signal. :-(
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
All Replies
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Re: smartcall help
Hi havince
  • 13
havince
Re: smartcall help
shame.
i posted a thread earlier about signal issues both me and my gf are having. had the above been possible it would have atleast sorted issues at home
