  • 6
lstarling73
s4 mini not connecting to wifi says saved secured yet won't connect
I am struggling with my S4 mini (4 months old), I am trying to connect to my wifi (sky broadband), everything looks find on the router - rebooted it just in case. I have reset my phone and re entered my wi fi password and also factory re-set the phone. All I get is the wifi is saved, secured, yet the phone won't actually connect. I have been on the general S4 forums but nothing they are saying makes any sense, i'm not stupid but i;m not a techie either i.e. speak english tell me exactly what I need to press or change to fix it. Anyone else having this problem and have you fixed it and how? Thanks
  • 1.58K
  • 101
  • 270
Re: s4 mini not connecting to wifi says saved secured yet won't connect
I had this problem exactly. In my case, it was fixed by setting the router to broadcast the SSID rather than hide it.
