Simon9
roaming
I am on holiday in spain. I set up roaming and it worked fine for a week but has now stopped working. How do I fix it?
  • 3.82K
  • 895
  • 1.7K
Re: roaming
Hi Simon9,
have you tried doing a manual network search to see if your phone can locate and reconnect to one of Virgin's partner networks?
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
Simon9
Re: roaming
Thanks. I rebooted the phone then did as you suggested and now it is working again.
  • 3.82K
  • 895
  • 1.7K
Re: roaming
Hi Simon09,
thanks for reporting back.
I'm pleased that it's working again for you now. Enjoy the rest of your holiday Smiley Happy
AlexKid :-)
