  • 8
baldbilluk
profound deaf and mobile packages excludes calls
Is there any special mobile packages for deaf  (non callusers)
I  am profoundly deaf with vm phone broadband and tv but I wanted to change to a vm mobile package but as I do not use phone calling I only use sms and the www is there any special packages or could virgin email me any packages that would exclude any 'telephoning' only sms/Internet and the size of internet data available, I look forward to hearing from u soon baldbilluk
Helpful Answers
  • 3.84K
  • 902
  • 1.7K
Re: profound deaf and mobile packages excludes calls
Hi baldbilluk,
the only package which doesn't include minutes would be Virgin Mobile's Pay As You Go "Big Data & Texts" tariff.
Here if you top up £10 you get 3000 texts + 1GB of 3G data the the following month. (Plus you still have your £10 top-up Smiley Happy)
£15 top up will get you 3000 texts + 3GB of 3G data the the following month.
A Pay Monthly SIM Only plan will give you minutes (even though you don't need them) but may still suit you better depending on your needs/budget:
£6 = Unlimited texts + 600MB of 4G data.
£9 = Unlimited texts + 2GB of 4G data.
There are also £12 and £25 tariffs.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
All Replies
  • 3.84K
  • 902
  • 1.7K
Hi baldbilluk,
AlexKid :-)
  • 297
  • 14
  • 39
Hey baldbilluk,
I have had a little check on the different packages we have, and @AlexKid is spot on, the best I can also see would be the Big data and texts bundle, this is a PAYG sim, if you top up £10.00 you will have 1GB data and 3000 texts or top up £15.00 and you will have 3G data and 3000 text messages.
I have included this information for you to read over, I hope this helps,
Take care,
Kelly
