hil
Message 1 of 5
no signal
does anyone know why there is no virgin mobile signal in sy19 7aa, been no signal for 4 days now. How do I contact virgin mobile, their website appears to be useless
thanks
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 2 of 5
Re: no signal
I put your postcode in here but there are no problems showing.
Do you know anyone else on Virgin or EE and are they having the same problem
You can ring 0345 6000 789 from a landline or other mobile to report.
hil
Message 3 of 5
Re: no signal
 Yes lots of people around here with same problem
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Message 4 of 5
Re: no signal
Then report it to Virgin on the number I gave
If they are on EE they should report it to them. Sometimes faults don't always show on the status checker
  • 13.68K
  • 561
  • 959
Message 5 of 5
Re: no signal
Hi hil
Welcome to the Community, I'm sorry to learn about the problems you're experiencing with your mobile service lately.
I've been able to locate your account and take a closer look at this from our end for you. We're seeing some slight problems with a mast in your local area although I'd expect the service to be a little intermittent, not completely down as it is.
As a result, I'd like to request that a replacement SIM is sent out, so that I can do that we'd need to confirm some information with you. To do that, could you respond to the private message I've sent with the requested information and I'll get right to it.
You can view the message by clicking the purple envelope on the top right of this page.
Speak soon
Craig
