bobcatbob
no signal at home
Before I signed up for a bundle deal including mobile I checked the area cover and found it to be "good" which was the same as my O2 provider, so I agreed to the bundle and kept my number and all went smoothly until I used my mobile at home... no signal. I checked the coverage map again but this time zoomed into where my house was supposed to be. I discovered that the actual pointer was in a field about 500 mtrs away and not  at my location. Read the small print and it says that the accuracy can't be guaranteed, 500 mtrs is a large error however on google maps and I can place a marker exactly where it should be.
I have the smartcall app which is connected to my virgin landline phone but I've paid for a mobile signal that doesn't exist in my home. So if I can't send or receive calls and text from my home I'll have to ditch the virgin bundle and go back to O2.
Is there an app to overcome my problem?
Helpful Answers
  • 3.82K
  • 899
  • 1.7K
Re: no signal at home
Hi bobcatbob,
unfortunately Virgin Mobile doesn't support calling over WiFi.
Also SmartCall is no longer available. It closed earlier this year: www.virginmedia.com/smartcall
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
No app. O2, and 3 do an app and EE use native wifi calling on some of the latest phones. But as you don't have a signal then EE is a no.
All Replies
  • 3.82K
  • 899
  • 1.7K
Hi bobcatbob,
AlexKid :-)
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
