fredradac
need help desperately
On holiday in France, told Vir Med in advance but have now been a fortnight without a signal, unable to send or receive texts or calls. Apart from swearing at Virgin what on earth can I do?
This is long past being a joke.
  • 3.82K
  • 897
  • 1.7K
Re: need help desperately
Hi fredradac,
log into your account > click on  the "Plan and device" tab.
Go to "Manage my services" > check that "Roaming" is set to ON & "International call barring" is set to OFF
This may be your problem. If so allow time for your account to update then reboot your phone by turning it off & on again.
You may also need to manually search for a network in the phone's settings.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
fredradac
Thank you, problem solved.
P.S. would like to award a Kudos but the link didn' t  work
  • 3.82K
  • 897
  • 1.7K
Hi fredradac,
glad I was able to help Smiley Happy
AlexKid :-)
