happychappy
Message 1 of 9
mobile sim up and running. can connect to home internet but cannot connect to internet on the go
Hi, received my virgin one month contract sim, I can connect to my home router and have internet, but i cannot get internet on the go, please help. Pete
Helpful Answers
  • 15.8K
  • 1.29K
  • 3.18K
Message 2 of 9
Re: mobile sim up and running. can connect to home internet but cannot connect to internet on the go
hiya @happychappy & pete, would need a bit more info, eg make/model of the phone, can you make calls using the new sim card?
here is all the manual settings needed -> http://www.geeksquad.co.uk/articles/virgin-apn-settings
  • 15.8K
  • 1.29K
  • 3.18K
Message 4 of 9
just to check can you make calls, or send txt messages?
  • 1.58K
  • 101
  • 270
Message 6 of 9
May be a couple of dumb questions - but are you subscribed to a tariff that gives you data? Is mobile data turned on?
  • 4.8K
  • 213
  • 439
Message 7 of 9
Hi Pete,
Welcome to the community and thanks for posting. I'm sorry to hear you can't get any internet outside of your house.
Thanks to everyone who has helped so far. Please take a look at a guide for your handset here. It will tell you how to turn on/off mobile data.
Please let us know if you require further assistance.
Rich
All Replies
  • 15.8K
  • 1.29K
  • 3.18K
Message 2 of 9
happychappy
Message 3 of 9
Thanks for your reply, yeah tried the settings  but still no luck, my phone is a Sony Xperia Tipo (st21i) and although it shows up on the geek squad website, it doesn't show up on the Virgin mobile site under 'find your phone'.
  • 15.8K
  • 1.29K
  • 3.18K
Message 4 of 9
happychappy
Message 5 of 9
Hi, thanks, yes everything working as it should be, incoming and outgoing messages and calls from anywhere, home and on the go but only getting internet on my mobile when I'm at home.
  • 1.58K
  • 101
  • 270
Message 6 of 9
  • 4.8K
  • 213
  • 439
Message 7 of 9
Hi Pete,
Rich
happychappy
Message 8 of 9
Yippee, thanks to everyone involved with my problem, I now have internet on the go.
  • 4.44K
  • 139
  • 333
Moderator
Moderator
Message 9 of 9
Hi happychappy,
Glad to hear this is all sorted for you now.
If you need us in future just get back to us.
Many thanks.
Take care
Stephen_B
Community Moderator
