Mart052
mobile signal problem
Hi new to forum,
I'm having a problem with my I phone 4 which is my own phone with a virgin pay monthly SIM card.
I tend to use this rather than my landline indoors as I get free minutes, only problem is that although I have a full signal indoors people cannot hear me due to phone constantly breaking up, could this be a phone fault or service fault as phone works fine outside with same number of signal bars.
any help would be appreciated.
Helpful Answers
  • 4.44K
  • 139
  • 333
Moderator
Moderator
Re: mobile signal problem
Hi Mart052,
Welcome to the forum and thanks for postingSmiley Happy
Sorry to hear you're having signal problems.
I kind of agree, this does sound like a signal issue indoors as you mentioned the phone works fine in other circumstances. Sometimes issues like this are simply just down to something as simple as the thickness of the walls.
I've provided a link here to a previous thread where potential solutions to this were discussed.
A potential solution for you if you have a Virgin Media landline is to use our smartcall app which allows you to make calls over wireless. Here is a link to our smart call help page for you.
Hope this helps.
Let me know if you need anything.
Stephen_B
Community Moderator
All Replies
  • 4.44K
  • 139
  • 333
Moderator
Moderator
Hi Mart052,
Hope this helps.
Stephen_B
Community Moderator
