erf29
mobile WiFi
Mobile window 10, how can I get mobile internet all the time is not just in wifi zones
  • 1.46K
  • 184
  • 378
enlli
Knows their stuff
Re: mobile WiFi
The title of your post is a bit confusing. I take it you are saying that you only get the internet when you are on wifi.
If this is the case then either mobile data is turned off on your phone or the correct settings have not been entered.
Here are the settings http://www.geeksquad.co.uk/articles/virgin-apn-settings#Windows%2010%20Mobile
