  • 5
cake66
lollipop update flickering screen on samsung s5 help
Hi had lollipop update a few weeks ago but now i have problems. sometimes get white block instead of numbers on lockscreen. but now i have problems with browser after a few times of using websites the top bit of screen flickers and its hard to scroll up or down and then keyboard jumps up and down. can any one help as it's getting frustrating?
  • 8.26K
  • 236
  • 340
Forum Team (Retired) Mat_H
Re: lollipop update flickering screen on samsung s5 help
Hi Cake66,
Sorry to hear you're having issues with your S5. So we can get this all sorted for you, I want to try a few quick things.
Firstly, are you able to perform a hard reboot by popping the battery out of the phone while it's turned on?
This should refresh the phones cache. Let me know how you get on.
Mat
  • 5
cake66
Hi Mat H
Yes I have tried that as sometimes screen goes black and unresponsive. I have done a factory reset and problem still there. After switching on flickering doesn't always start straight away a few mins after using apps it starts. email, messenger, settings etc
  • 4.44K
  • 139
  • 333
Moderator
Moderator
Hi cake66,
Thanks for getting back to usSmiley Happy
Matt is away from the office at the moment so I've jumped on this for him.
Sounds like this issue is going to be linked to the lollipop upgrade. Even when you do a factory reset it will still leave lollipop installed. Looking around the internet there are a few people complaining about this issue since the update.
One of the suggestions that's been made is to turn off power save mode. You can normally do this by sliding the top menu down and deselecting it here. You could also try increasing the brightness as well to see if this stops the flickering.
Let me know how this goes.
Many thanks
Stephen_B
Community Moderator
