paulm100
iphone Charger Replacement
We have had a iphone on contract with Virgin for around 4 months and the charger is no longer working. I cannot find any email contact or online contact form on the Virgin website or help pages so I'm posting here. I don't want to be ringing and being put on hold for ever so I want to deal with this as much as possible without ringing up.
How do we get the charger replaced?  I believe it would be covered under warranty so can I take it into a virgin shop for a replacement or can a replacement be ordered online?
Unfortunately the website is so bad I cannot find an answer to this anywhere.
Any help would be appreciated.
  • 329
  • 23
  • 83
KeithW
Fibre optic
Re: iphone Charger Replacement
Take it into an Apple store, as it is under warranty they will replace it free of charge
Hope this helps
All the voices in my head are my own voices - Find your own!
If I have helped you then please click on the "thumbs up" icon.
If you feel I have helped to solve your problem then please mark my message as a "Helpful Answer"
Tags (3)
  • 18
Koala5
Or a Virgin store, or ring 789 from your phone assuming you have managed to charge it.
  • 123
  • 8
  • 16
alpha123
Up to speed
I wouldnt go to a store with it. When i worked in stores we were never given any spares for anything like that
