johnnylynch
how do you switch storage etc from phone to sd card on galaxy ace
how do you switch from phone memory to sd card on galaxy ace
  • 12.67K
  • 1.61K
  • 3.73K
Re: how do you switch storage etc from phone to sd card on galaxy ace
Without knowing the model number and Android OS version, there are some suggested places to tweak:
* Settings -> "Save to" -> then change the settings.
* And in general each app may have its own configurable option regarding how it stores files.
This page lists some lists some of the apps which have that option: http://cellphoneforums.net/samsung-galaxy/t373664-samsung-galaxy-ace-4-full-guide-sd-card-external-s... but basically it is the steps to follow is: A) Open the app, B) Go into its settings and lastly, C) Set to save whatever it makes to the the SD card rather than internal memory.
Certain versions of android don't allow moving apps to SD card, if that was something you had in mind. However, even if possible, some apps, like VM's TV Anywhere don't run/update when stored on a SD card.
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
