Stuart1234
Just joined
how do i set mobile phone to home wifi so i wont be using my phone tarrif
how do i set mobile phone to home wi fi so i wont be using my phone tarrif
  • 141
  • 6
space_cowby
Superfast
Re: how do i set mobile phone to home wifi so i wont be using my phone tarrif
just connect to your home WiFi and thats it really.
Either leave WiFi on or remember to turn it on when home.
  • 4.43K
  • 139
  • 333
Moderator
Moderator
Hi stuart1234,
Welcome to the forum and thanks for posting with usSmiley Happy
I can see you've had some help already from space_cowboy which is great.
Did you manage to get connected to your home WiFi in the end?
You could download the your account app to your handset which will keep you up to date with your usage.
If you are ever concerned you are using to much data you can always turn it off on the phone. I've included our phone guide here which has numerous handset guides.
Hope this helps.
Let us know if you need anything else.
Stephen_B
Community Moderator
