  • 196
  • 11
leah_no1auntie
Up to speed
delete posts
can you delete posts that you write on here ?
Helpful Answers
  • 12.66K
  • 1.61K
  • 3.73K
Re: delete posts
Afraid not. You can however click the 'Flag for a moderator' link on the post of yours that you want removed. Report that you want your post removed. If you want a topic you started removed, they would accommodate you with that too.
As an aside, a member of the Superuser group can pull posts from circulation into a section where posts are queued for removal. So if you edited your post to say "deleted, please remove." Then we'd know to do that for you.
The first option (moderation team route) is the better option to use though.
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
All Replies
  • 12.66K
  • 1.61K
  • 3.73K
Re: delete posts
  • 196
  • 11
leah_no1auntie
Up to speed
Re: delete posts
thanks Smiley Happy
