  • 5
SimonF15
data roaming abroad
Hello,
I have an Iphone 5c running IOS8. I am currently in Portugal. I can text and make calls. I am conected to the partner MOS.
I purchased a 10mb data package two days ago. I got a text confirming it was purchased. A status check shows it is available and the 30 day clock is ticking.
Mobile data is enabled
Data roaming is enabled.
European Internet is on
I have reset my network settings since I purchased (suggested elsewhere)
I am not seeing a data connection. I cannot use the internet.
Any ideas please?
Tags (1)
  • 5
SimonF15
Re: data roaming abroad
My bad, the partner is MEO, but I have also tried forcing connection to NOS and vodafone P.
Also tried in different locations including up a mountain ;-)
Since writing this I have found a load of this type of problem, going back many months, so it appears that this is a regular problem ;-( I will just have to accept that it won't work, as the Virgin standard answer seems to be "it must be the carrier at the otehr end" or in my case all three carriers (go figure!!!!)
So I suppose my question now is how do I get a refund?
  • 1.42K
  • 10
Moderator Danni_M
Moderator
Hi Simonf15,
Apologies for the troubles you're having.
I've sent you a private message about this which you can access my clicking the red envelope at the top right of the forum Smiley Happy
Many thanks,
Danni_M
  • 5
SimonF15
Thank you. I have replied hope you can help.
