CliveE
Message 1 of 10
Wifi hot spots
Are the reported hotspots only for the use of  virgin mobile customers?
Helpful Answers
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Message 3 of 10
Re: Wifi hot spots
Don't forget they are not secure, so don'y buy anyrthing/check you bank or log onto anywhere you have a secure password, there great for browsing and you tube type stuff Smiley Happy
All Replies
  • 198
  • 18
SonarUK
Superfast
Message 2 of 10
Re: Wifi hot spots
WiFi on the go for Virgin Mobile customers
WiFi Buddy helps Virgin Mobile customers effortlessly auto-connect to 1000s of WiFi hotspots - at no extra cost – when out and about in cafes, bars, shops and restaurants. No need to sign in – we’ll recognise your Virgin Mobile SIM. It’s just one of The Inclusives you get for being a Virgin Media customer.
http://store.virginmedia.com/discover/mobile/using-your-mobile/wifi.html
Offline System Update Diagnostic Tool on Xbox One: http://bit.ly/1e8bSs3
Network ports used by Xbox Live on Xbox One: http://bit.ly/1dCNLm0
xBox Support: http://bit.ly/1lE2QrK
Xbox One operating system versions and system updates: http://bit.ly/1NiJS1j
www.twitch.tv/familycreations
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Message 3 of 10
Re: Wifi hot spots
  • 12.67K
  • 1.61K
  • 3.73K
Message 4 of 10
Re: Wifi hot spots
The other WiFi scheme which is in trial currently is open to Virgin Media customers who have the broadband package and are opted into the WiFi sharing, not just mobile customers.
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
CliveE
Message 5 of 10
Re: Wifi hot spots
Yes, I understand that part, but is it ONLY for people with virgin mobile, as vm want me to use my super hub as a hot spot, is it not, therefore , fair that I can use the hot spots when out and about.
I don,t need a phone contract, I am a low user and use FreedomPop , free calls and texts.
  • 1.87K
  • 174
  • 338
J0hn
Super solver
Message 6 of 10
Re: Wifi hot spots
you can logonto other free site weatherspoons lots of pubs shops and cafe's as well Smiley Happy
and yes it for Virgin folks
Sky have a similar option for there customers as do BT
CliveE
Message 7 of 10
Re: Wifi hot spots
Sorry Shelke, was typing and did not see your post.
So my scenario in being tested, though if the hotspots exists, what testing is needed ?
  • 12.67K
  • 1.61K
  • 3.73K
Message 8 of 10
Re: Wifi hot spots
Regarding the WiFi scheme Virgin Media aim to launch in the near future (like BT FON): Firmware updates are required to get the hubs to broadcast the WiFi hotspots. Currently only the Superhub 2 has trial firmware for it. Last time around it was tested, it had too many bugs and was pulled. However, the hub 2 once again has trial firmware in the selected trial area (Reading.) They'll be testing its effects and uptake in the trial area of the WiFi scheme. If all goes well, it will roll out nation wide and eventually all Superhubs will have new firmware which supports the WiFi sharing. So you should see MANY Virgin Media hotspots about the UK in the not too distant future.
bobinw
Message 9 of 10
Re: Wifi hot spots
As far as I know it is only for virgin mobile customers. I have opted out for my hub to be used in my profile settings but it still is broadcasting as a public hotspot which is very annoying.
  • 1.58K
  • 101
  • 270
Message 10 of 10
Re: Wifi hot spots
Is your private wifi turned on?
