NottinghamND
Why does bluetooth keep disconnecting and re-connecting in my car?
I recently purchased a new Virgin phone and paired the bluetooth with the one fiited to my car. However every time I get in the car the bluetooth disconnects and re-connects up to twelve times or until I have to pull up and turn it off. This did not happen with my prevous phone (not Virgin).
  • 4.45K
  • 139
  • 333
Moderator
Moderator
Re: Why does bluetooth keep disconnecting and re-connecting in my car?
Hi NottinghamND,
Welcome to the communitySmiley Happy
Sorry to hear your Bluetooth is playing up.
Bluetooth device connection can be a bit temperamental at the best of times. A quick Google search finds many results where by others are describing a similar scenario.
I would probably check with the manufacturers handbook to make sure your handset is supported by the Bluetooth system in the car.
Hope this helps.
Let us know how it goes.
Stephen_B
Community Moderator
NottinghamND
Thanks for you reply Stephen, the problem seems to have sorted itself out on its own so I'll see how it goes.
  • 4.45K
  • 139
  • 333
Moderator
Moderator
Hi NottinghamND.
Thanks for letting me know.
Glad to hear its resolved itself. Hopefully it stays that waySmiley Happy
Any further issues let me know.
Take care
Stephen_B
Community Moderator
