Bow-cage
Waist of my time, well in my 70's , simple question needs a simple answer Able to use or not?
 So can I use my mobile or not. Simple answer  yes/ no will do just dail home?
  • 7.22K
  • 806
  • 3.03K
Re: Waist of my time, well in my 70's , simple question needs a simple answer Able to use or not?
I this anything to do with your question here - otherwise I am puzzled by this to the extent that I don't know what it means?
http://community.virginmedia.com/t5/Mobile/Can-now-when-abroad-use-my-own-mobile-to-ring-home/m-p/28...
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
