Mattloftus
Voicemail problem
I've just ported my number across to virgin which took much longer than I was told, and my voicemail now won't work. Everything is on and activated, but when I try to dial 222 I get a 'can't connect right now' message and then it hangs up. I know I have messages on my voicemail and I need to hear them for work. Please help!
  • 20
Talamat
Re: Voicemail problem
Thought 222 was just to setup voicemail. Isn't there a specific number to dial to actually access your voicemails?
  • 7.68K
  • 242
  • 538
Hi Mattloftus,
Welcome to the Community Forum and thanks for your post. I'm sorry to hear that you are experiencing a problem with you voicemail.
@Talamat is correct, 222 is used to set up your voicemail service. To pick up your messages, hold down the "1" key on your phone to connect to your voicemail inbox.
Sometimes after a number port, the voicemail service can take up to 72 hours to activate. Is this working for you now?
If you are still having a problem with your voicemail service, please let me know and I will look into this for you. I'll send you a private message requesting further details. Just check the envelope icon at the top right of this page.
You can also find further assistance on our online Help & Support pages here: Virgin Mobile Voicemail
Kind regards,
Terri
Virgin Media Forum Team
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
