lainie04
Voicemail not setting up
When I dial 222 to set up the voicemail I get the message "sorry but your call cannot be connected at this time". This has been the same for days. When I dial 789, I get the message "it is not possible to be connected to an advisor at the moment' message before the call disconnects itself. Can you help? Like many others, I depend on voicemail and need this set up ASAP.
  • 4.04K
  • 941
  • 1.78K
Re: Voicemail not setting up
Hi Iainie04,
it may be that your voicemail service needs resetting but it would be necessary for a customer service agent to do this.
I'm concerned that you are unable to connect via 789. I've just tried from my own mobile, no problem.
Try dialing 150 (also a free call) > option 2 (for mobile) and see if this will allow you to connect to an advisor who hopefully will be able to help you with your voicemail.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
lainie04
Thank you AlexKid,
I eventually managed to get through to them. Some options I was selecting were cutting me off, other taking me back to the welcome message. They have been trying to re-set the voicemail from their end and have been so for nearly 3 hours! Hopefully they can manage to sort it their end.
  • 15.49K
  • 641
  • 1.04K
Hi Lainie04
Welcome to the Community, I'm very sorry for the problems you're experiencing with your Voicemail service recently.
I've located your account to take a closer look at this and I can see we've spoken to you about this and reset your voicemail, I hope this means that you were able to get it set up?
We'll be here if you need any assistance moving forwardMan Happy
Craig
