PR2
Virgin mobile roaming in Greenland?
Will my iPhone 5s work with Virgin roaming in Greenland?
What will the cost be please?
  • 7.24K
  • 810
  • 3.04K
Re: Virgin mobile roaming in Greenland?
Greenland is not listed in the countries with which VM has roaming agreements.
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
