  • 15
Sorcerer57
Virgin Alcatel Pixi 3 4.5 Inch 5MP 4GB 3G Android
I am thinking of buying the above phone from Argos for my wife. She is a Virgin customer (SIM only). Argos say the Network provider for this phone is Virgin.
Will it be simply a case of my wife taking the SIM from her current phone and inserting in new phone? Her current phone (ex Virgin) is a Sony Xperia C2105.
Thanks for any help /advice.
  • 3.83K
  • 899
  • 1.7K
Re: Virgin Alcatel Pixi 3 4.5 Inch 5MP 4GB 3G Android
Hi Sorcerer57,
yes, provided that the new phone accepts the same size SIM (or your wife has one of the newer "triple cut" SIM's).
If you find you do need a replacement SIM, it's just a mater of a call to customer services 789.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
