DemetraSavva
Message 1 of 5
Top up my minutes on monthly plan
Hi, is there any way to top up my minutes on my monthly plan? I run out of minutes and my phone is not working now
  • 4.04K
  • 942
  • 1.78K
Message 2 of 5
Re: Top up my minutes on monthly plan
Hi DemetraSavva,
unfortunately not, Virgin Mobile don't do "extra add-on" allowances.
If you continue to use airtime minutes outside of your allowance as a Pay As You Go customer you'll be charged at your standard rate.
As a Pay Monthly customer on a SIM only plan you'll be charged 45p per minute.
Your phone is not working now?
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
DemetraSavva
Message 3 of 5
Thank you for your reply
That is so unfortunate. Yes my mobile is not working. I even top up with more money.
  • 4.04K
  • 942
  • 1.78K
Message 4 of 5
Hi DemetraSavva,
what phone do you have?
Is the problem with your handset or your VM account? (What exactly isn't working?)
AlexKid :-)
  • 1.1K
  • 103
  • 207
LittleMick73
Knows their stuff
Message 5 of 5
If you are over running your allowance you might like to look at increasing your deal, I know it will cost a bit more but might be better in the long term.Regards Micky
