Clanway
Technical issue
I made an order for a mobile contract online yesterday had 3 emails and then nothing to confirm that the order has veen accepted can anyone help
  • 3.82K
  • 895
  • 1.7K
Re: Technical issue
Hi Clanway,
if you had typed "technical" into the search bar of this forum.
You would see that you are yet another person facing this unfortunate and on-going problem:
http://community.virginmedia.com/t5/forums/searchpage/tab/message?filter=labels&q=technical+glitch
I can only suggest that you give Virgin mobile customer services a call on 789 from a Virgin mobile if you already have one
Or 0345 6000 789 from any other phone and see if they can advise you.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
