  • 11
Ian_
Message 1 of 5
SmartCall wrong setting
The SmartCall setting on my Galaxy S3 shows 'Talk Weekends' when my plan is 'Talk Unlimited'.  This stops me using SmartCall during weekdays.  Anyone know how to fix this.
Thanks.
Helpful Answers
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Message 5 of 5
Re: SmartCall wrong setting
Thanks.
Best advice would be to pop this question over into the landline phone section, usually gets seen quicker by staff.
It's a problem which has risen quite a lot lately, usally down to a wrong setting somewhere which staff can easily rectify for you. :-)
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
All Replies
  • 2.26K
  • 30
  • 199
jhuk
Knows their stuff
Message 2 of 5
Mines shows the same, not sure if simply a glitch of will effect calls cost.
Just checked om My VM site APP's and its showing proper Talk Unlimited.
  • 11
Ian_
Message 3 of 5
Hi jhuk,
It's not that it will affect call costs, it's that I can't make calls using SmartCall, as it gives me the message
'This isn't a SmartCall' and 'This call isn't included in you talk plan.  Do you want to make a normal call from your mobile?''
My VM App page also tells me, correctly, that I have 'Talk Unlimited', though SmartCall settings say 'Talk Weekends'.
  • 2.26K
  • 30
  • 199
jhuk
Knows their stuff
Message 4 of 5
Ah bummer, I have not used my phone to make a call lately as signal is poor since May 2015.
I know Smartcall is to help with this but if I am home I just use my landline for the very few calls I make.
 Use my mobile on wifi for listening to music with earphones in when I want peace etc.
The time I tested Smartcall the call the sound quality was different from over the mobile network, poorer IMO.
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Message 5 of 5
Thanks.
