  • 22
dcweather
Sim card requires pin after power off
Have upgraded to 4G sim (which seems superb so far). Only thing is every time I power down my phone it asks for  sim card pin when I turn on. Never had this with any phone before or this phone (Moto 3G). It's a pain having yet another pin to remember - is there a setting to stop this?
Dave
Helpful Answers
  • 21.77K
  • 800
  • 3.13K
Re: Sim card requires pin after power off
check in the phone's security setting you could have an option to disaale the sim lock pin
irst, go to Settings in your Android device's main menu. In the Settings menu, choose Security, then Set up SIM card lock. First, here's how to disable the SIM card PIN. All you have to do is to uncheck the box next to Lock SIM card, and then confirm the change by inputting the current PIN code.
All Replies
  • 21.77K
  • 800
  • 3.13K
  • 22
dcweather
Many thanks, that was it. Off must have been default setting in this and previous phones I guess.
