cah82
Setting up Voicemail
I'm trying to set up voicemail for the first time.  It wasn't activated when I first had the phone last year. When I ring 222 it asks for my pin number which I don't have.  So where do I go from here?
  • 3.82K
  • 896
  • 1.7K
Re: Setting up Voicemail
Hi cah82,
call customer services (free) on 789 and ask them to reset your voicemail.
Then run through the "set up" procedure described in this link: How do I set up voicemail?
(Virgin have recently updated/changed their voicemail, the "change mailbox features" may be a different option now).
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
cah82
Thanks so much Alex I'll give that a try.
