joe183
Just joined
Samsung s3 Note not registered to network
My samsung S3 Note keeps telling me that it is not registered to network. I am on virgin and was overseas until yesterday.
thank you
JOe
  • 3.82K
  • 896
  • 1.7K
Re: Samsung s3 Note not registered to network
Hi Joe,
I'm sure you will have already tried turning it off & on again? This should make it search for a network.
If the battery is removable you could try taking it out whilst the phone is turned on, then replace it & turn the phone back on, This will reboot the phone. (If the battery isn't removable, try holding the power button down & it may give the option to reboot).
Are you able to go into the phone settings & manually select a network?
If non of the above work, you could also try taking the SIM card out & putting it back again, then turn on the phone.
AlexKid :-)
If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also
