oct63
SIM card not connecting
My virgin sim has stopped connecting to a network. I've tried another network sim in the phone and it works fine.
  • 3.81K
  • 893
  • 1.7K
Re: SIM card not connecting
Hi oct63,
good idea trying another network SIM in your phone so at least now you know your phone is OK. - I assume therefore that it's an unlocked handset?
Are you on p.a.y.g or contract with Virgin – is your account upto date?
With your Virgin SIM in are you able to go into the phone settings & manually select a network? - It may say T mobile or EE, not just Virgin.
if you’re still unable to connect to the network you could give Virgin mobile customer services a call on 789 from another Virgin mobile or 0345 6000 789 from any other phone and see if they can help. (It may be a problem with your SIM or it may just be an area fault that hopefully they're onto).
AlexKid :-)
____________________________________________________________________
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
oct63
Thanks for the reply, very helpful.
