david30
Roaming
Where do I find Manage Services to turn on roaming. Can anyone help.
  • 4.03K
  • 941
  • 1.78K
Re: Roaming
Hi david30,
log into your Virgin Mobile account then click on  the "Plan and device" tab.
You will find "Manage my services" here.
Set "Roaming" to ON & "International call barring" needs to be set to OFF
Make the change by moving the "switch" in your account.
(Click the other side of the rectangle box).
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
