  • 21
andydd
Message 1 of 16
Roaming not working AGAIN !
Exact same thing as last year, my phone is set up for roaming, yet i arrive in France and it doesn't work !
Same as last year, I ended up getting the CEO involved who fixed it.
Why is this happening !!!
Virgin account say Roaming is On, phone is set up for roaming.
I have connection to Orangd FR, I cant call out or text (or use data) trying to reach any website gets the Text 23456 message but when I try this the texts can't be delivered.
Help ! I do NOT want to have to go through the same hassle as last year !
Andrew Daley
Tags (1)
  • 21
andydd
Message 2 of 16
Re: Roaming not working AGAIN !
Deleted
  • 3.83K
  • 899
  • 1.7K
Message 3 of 16
Hi andydd,
it sounds that although you may have roaming active you may also have international call barring active.
Log into your account > click on  the "Plan and device" tab.
Go to "Manage my services" > "Roaming" should be ON & "International call barring" needs to be set to OFF
If not, make it so by moving the "switch".
Allow time for your account to update if you have to make a change to the settings.
(Virgin advise that this may take upto 24 hours).
Then reboot your phone by turning it off & on again.
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 2.18K
  • 242
  • 567
teabag
Problem sorter
Message 4 of 16
Sounds like "international call barring" is turned on in your account, you can change this yourself using your online account - you'll need to find some WiFi first of cause.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
  • 21
andydd
Message 5 of 16
Alas international barring is off.
Although roaming dies show as On when I click to make changes it shows as off again.
What I want is to be able to contact Virgin but I can't call them !
  • 3.83K
  • 899
  • 1.7K
Message 6 of 16
Hi andydd,
you may be able to contact Virgin here: Help and Support - Contact Us > Mobile > Mobile not working > Chat online.
The advisors are often busy though so you may not get connected straight away.
If you are able to use another phone. Their UK support line number is: +447953 967 967
AlexKid :-)
  • 21
andydd
Message 7 of 16
Thanks I'll try although when same thing happened last year the chat feature never worked.
  • 21
andydd
Message 8 of 16
Can't see a chat online feature
  • 3.83K
  • 899
  • 1.7K
Message 9 of 16
Hi andydd,
that always seems to be the case with webchat Smiley Sad
All I can suggest if you have a good WIFI connection is that you remain on the page and keep refreshing it every few minutes.
Good luck, post back if you manage to get things sorted.
AlexKid :-)
  • 21
andydd
Message 10 of 16
Can't even find web chat at all now, you got direct link ?
