Orwell1963
Message 1 of 13
Roaming in malta
I am currently in Malta and cannot make or receive calls or texts. Everything is turned on.
  • 227
  • 20
  • 45
scouser73
Superfast
Message 2 of 13
Re: Roaming in malta
Hi Orwell1963,
Did you call Customer Services and ask them to activate Roaming, before you left the UK?
If not, then you will need to do this before you go abroad next time.
http://store.virginmedia.com/discover/mobile/using-your-mobile/abroad.html
Regards,
scouser73
152 Mbp/s Broadband - Windows 10 [Home] - SuperHub 3.0 - HTC Desire 825
Orwell1963
Message 3 of 13
Thanks, I realise I should have done that but it should be made clearer on the website.
However, I followed instructions given in response to another post . You can activate roaming via your online account. Obviously you need some sort of internet access to do this but I am now receiving my calls.
  • 79
  • 12
TaiChiMan
Dialled in
Message 4 of 13
I am in malta and cannot do anything with phone no outgoing calls or messaging it is NOT clear you need to call customer services my account has roaming turned on that should be enough
Orwell1963
Message 5 of 13
Roaming was turned on on my phone but I could make calls. I eventually got round it by logging into my virgin mobile account. Roaming was turned off there. I can't remember exactly where it was but it was difficult to find but I did eventually. I can now use my phone abroad without problem.
  • 3.82K
  • 896
  • 1.7K
Message 6 of 13
Hi TaiChiMan,
as well as Roaming on, you also need to have International call barring off in your account settings:
 Log in to your account > click on  the "Plan and device" tab.
Go to "Manage my services" you have already said that Roaming is on. Check that "International call barring" is set to OFF
If it is not, make the change by moving the "switch" in your account.
(Click the other side of the rectangle box).
Allow time for your account to update then reboot your phone.
Check that international roaming is active in the settings on your device itself.
You may have to do a manual search for network.
Good luck Smiley Happy
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
  • 79
  • 12
TaiChiMan
Dialled in
Message 7 of 13
Thanks Alex tried all of these including phone specific but no joy just quirky old virgin I bet
  • 6.85K
  • 217
  • 510
Message 8 of 13
Hi TaiChiMan,
I'm sorry that your data roaming isn't working while you're in Malta. Has this been sorted out for you?
If you are still having problems, please let me know. I'll need to verify your details in order to look into this, so I'll send you a private message requesting more information. Just check the envelope icon at the top right of this screen.
Kind regards,
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
  • 79
  • 12
TaiChiMan
Dialled in
Message 9 of 13
well back home and everything is working again - shame I never found out what the problem was
  • 4.95K
  • 146
  • 282
Forum Team (Retired) BenD_H
Message 10 of 13
Hi TaiChiMan Smiley Happy
Thanks for your reply and glad you've arrived safely home Smiley Happy Check out the post another member made about Roaming and more specifically the APN settings Smiley Happy
Keep in touch and thank you.
Ben
